Проблем с ключ
    Намерих това, само, че е за коли с ключове. Предполагам за 159 се поставя металния ключ до гнездото за елктрония ключ и се натиска START. След това се въвежда кода от картата с педала на газта. Пак казвам, предполага! Но в края има предупреждение, че след такава процедура пак трябва да се посети сервиз на Алфа, тъй като тази процедура ще трябва да се повтаря при всяко стартиране на двигатела. Според мен е най-добре да се обадиш в представителстово на Алфа и да питаш какво може да се направи.... Въпреки, че най-вероятно ще ти предложат варианта с нов ключ
    If the Alfa Romeo CODE system is not able
    to deactivate the engine inhibitor, warning
    lights ¢ and U remain lit and the engine
    cannot be started. To start the engine it is
    necessary to follow the emergency starting
    procedure.
    IMPORTANT You are advised to care-
    fully read the entire procedure before car-
    rying it out.
    If a mistake is made during the emergency
    procedure, the ignition key should be turned
    to STOP and the operations must be re-
    peated from the start (point 1).
    1) Read the 5-figure electronic code on
    the CODE card.
    2) Turn the ignition key to the MAR po-
    sition.
    3) Fully depress the accelerator pedal and
    keep it pressed. The warning light U will
    come on for eight seconds approximately
    and will then go out; now release the ac-
    celerator pedal.
    4) The warning light U begins to flash:
    after it has flashed for the same number of
    times as the first digit on the code of the
    card, press completely and hold down the
    accelerator pedal until the warning light U
    comes on (for 4 seconds) and then goes out
    again; now release the accelerator pedal.
    5) The warning light U will begin to
    flash: after it has flashed for the same num-
    ber of times as the second digit on the code
    of the card, press completely and hold down
    6) Repeat this procedure in the same way
    for the other digits on the CODE card code.
    7) After entering the last figure, keep the
    accelerator pedal pressed. The warning light
    U turns on (for four seconds) and then goes
    off; now release the accelerator pedal.
    A quick flash of the warning light U
    (for appr. 4 seconds) confirms that the op-
    eration has taken place correctly.
    9) Start the car turning the ignition key
    from the MAR position to the AVV posi-
    tion without returning the key to the STOP
    position.
    Conversely, if the warning light U stays
    on, turn the ignition key to STOP and re-
    peat the procedure starting from point 1).
    IMPORTANT After emergency starting
    it is advisable to turn to an Alfa Romeo Au-
    thorized Service, because the procedure de-
    scribed must be repeated each time the en-
    gine is started.
      Нестава нищо мерси се пак
      Няко може ли да ми каже дали ако траспондера не е за моя модел кола ще се получат тия осложнениа а именно колата да не дава на контакт като забода ключа. Защто мисла че тук е грешката на ключара.
        Не е от транспондерът , от друго е!
